New Project 2011/2012 /2013/2014!!
z1000puddin
#106 PostAuthor: z1000puddin » Thu Jun 06, 2013 10:07 pm
Wow al
That is one amazing reply-
Firstly the order was 4-3-1-2
Fuel was in the carbs.
Plugs 3,2&1 were still fitted during pot #4 was tested,,
Plug 4 was not fitted during test on #3 & so on.
All plugs are straw brown colour.
I will test again tomorrow,with no fuel & colder engine - that will be safer as I burnt my bloody hand getting the gauge out :evil:
Thanks again
Stu
Zed til Dead
RALPHARAMA
#107 PostAuthor: RALPHARAMA » Fri Jun 07, 2013 7:07 am
You should take all the plugs out and perform the test on the engine at room temperature. Ideally drain the float bowls and ensure the petrol tap is off.
Compression tests give you an idea, but are not necessarily especially accurate and the values recorded should not be taken as gospel, unless you've wedged up for a profession tool, however the comparison between cylinders is the important thing ie they're all in the same ball park.
The fact that all the plugs are the right colour is a good start. As long as it's running OK I would suggest getting it on a dyno for a real picture of how it's running - my local place only charges £30 for a run and you get some seriously useful info.
Ralph Ferrand
#108 PostAuthor: zed1015 » Fri Jun 07, 2013 8:17 am
You have too much time on your hands.
If the plugs are all consistant and it runs ok i'd hide the comp tester and just ride the thing.
The motor is all fresh isn't it ?
You need to put a good few hundred miles on it while the weather allows to give the motor time to bed in .
Give it a comp test when it's time to re-torque the head and check the shims in 500 miles or so.
z1000puddin
#109 PostAuthor: z1000puddin » Fri Jun 07, 2013 5:24 pm
:D :D
Your right zed1015 - Far too much time. :D :D
I was fiddling again today.
Garage temp was 15 degrees
Float bowls drained
All plugs removed - Results below
#1- 175 psi
#2 -170 psi
#3 -165 psi
#4 -180 psi
Previous results below
#1 - 160 psi
#2 - 155 psi
#3 - 165 psi
#4 - 175 psi
So Its all back together and away to get some more miles on it.
And I promise not to tinker with it any-more ( until I get it on the Dyno)
Stu
Zed til Dead
Jay1969
#110 PostAuthor: Jay1969 » Mon Dec 16, 2013 10:23 pm
[quote="z1000puddin"]Finally braved the cold to fit the front end & rear wheel
I will need to get Mrs puddin to give me a lift down this week end
:shock: ( I need to invest in a bike lift next time)
Hi Stu,
If you still need a bike lift, I highly recommend EazyRizer http://www.on-bike.com/
(Click on picture below to view video of it in operation)
z1000puddin
#111 PostAuthor: z1000puddin » Thu Jun 12, 2014 9:52 pm
Had a very nice letter in from DVLA yesterday :D
After around 18 months of unbelievable DVLA, Police hassles which I wont bore you all with.
My age related reg number for my green 1075 project turned up :D :D :D
My new number plate is on its way now & should be fitted by the weekend.
I would like to take this opertunity to thank Rick Brett & Jerry Humpage for the help & assistance on this matter over the last few months.
A few times I nearly gave up & thought about breaking the bike up.
Stu
Zed til Dead
Jay1969
#112 PostAuthor: Jay1969 » Fri Jun 13, 2014 6:24 am
Such a relief you didn't resort to breaking your awesome Zed for parts Stu!
I feel really pleased for you! Well done Jerry and RB :up
Is Vic There
#113 PostAuthor: Is Vic There » Fri Jun 13, 2014 7:53 am
That's very nice, love the detain in it
#114 PostAuthor: Pigford » Fri Jun 13, 2014 1:45 pm
LUSH - but we need a proper "rear-end" view :twisted:
Flying Tiger
Ted's Biatch
#115 PostAuthor: Flying Tiger » Fri Jun 13, 2014 2:30 pm
Looking good Stu!
sanderz
Re: Paint set now on
#116 PostAuthor: sanderz » Fri Jun 13, 2014 4:55 pm
z1000puddin wrote:
Very, very nice that - A real beauty :drool
Chuffed you've got all the dramas sorted out, time now for you to enjoy the rest of the summer :up
Wots up DOHC
Padders
#117 PostAuthor: Padders » Fri Jun 13, 2014 5:20 pm
Now that I like nice to see something different.
PUM 13
Users browsing this forum: No registered users and 5 guests
