Carb overflows
Carb overflows
How long should the carb overflow pipes be? I got some pipe from ZPower but it looks tight for length.
So ow long should they drop past the frame?
Bike now finished what a joy!
its the battery overflow pipe that you need to worry about. fuel normally only leaks out of the overflow when the bike is stationary or the fuel is left on especially with old bikes no matter how clean you think your tank is micro particles will still get through the filters & cause the float needles not to seat & fuel level will rise & run out of the overflow pipes. if your battery is over filled with acid or your charging system is over charging the battery it will run through the overflow & ruin the chrome on your wheels & your exhaust system then you will feel sick
I need to check the carb floats, yes i should have done this off the bike! but i'm still learning from my mistakes.
i understand i need to use clear pipe from the carb drain plug. What do i use in the drain plug that i can connect the clear pipe to without petrol pouring out?
i have the genuine tool you can borrow but i would require a refundable deposit & cost of postage on its safe return.or you can but this from z1 enterprises
http://www.z1enterprises.com/ItemDetail ... =ZSM01-208
genuine kawasaki tool
Wayne1960 wrote:I need to check the carb floats, yes i should have done this off the bike! but i'm still learning from my mistakes.
You can make a manometer thats a cheapo version of the proper one Z1b man shows,go to your local aquatics they sell clear air tube,get an inline plastic coupler for the tube,screw it into the bottom of the float bowl and attach pipe,tape to side if bowl to see level...Paul j
z1bman wrote:its the battery overflow pipe that you need to worry about. fuel normally only leaks out of the overflow when the bike is stationary or the fuel is left on especially with old bikes no matter how clean you think your tank is micro particles will still get through the filters & cause the float needles not to seat & fuel level will rise & run out of the overflow pipes. if your battery is over filled with acid or your charging system is over charging the battery it will run through the overflow & ruin the chrome on your wheels & your exhaust system then you will feel sick![]()
Wayne - to prevent you "feeling sick" as z1bman puts it, buy a gel battery!
http://www.motorcycleproducts.co.uk/bat ... 29726.html
they hold a much better charge (keep them on a trickle charger during when not riding) and have a better cranking power
than lead-acid batteries.
Non standard Z900 - purchased from HIGGSPEED - http://www.higgspeed.com/ -
http://www.z1ownersclub.co.uk/forum/vie ... 6a7d5e816c
