This was Snetterton the other day.
1100R with a 130 back tyre and it does not surprise me as he is a speed demon.
Will both be there at the end of the month.
Get the sound turned up.
http://www.youtube.com/watch?v=3EZmQCq8syU
Onboard with Brian 1100R
						- paul doran
Good posting there Al
Powered passed that Repsol
Watched the other view as well, brilliant - https://www.youtube.com/watch?v=dHDq7ed00r8
Wots up DOHC
						Knee down with standard casings ooh I bet that was close.
In fact I would love to see some pics with knee down on standard casings to see just how close it is especially on the alternator side.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
He rode there from this end and back home at the end of the day i believe
Here's the motley crew at Cadwell last year, when he went past me i thought i was breaking down or running out of petrol
 . Bas^&*d
http://www.z1ownersclub.co.uk/forum/vie ... c&start=45
						- brian 1100
So now anyone else tempted to do the Classic Bike Trackday in August at Cadwell? You don't need a modern bike to have fun.
For those wondering about the engine spec.
1170cc but standard 9.5:1 compression pistons, flowed head by Debben, Mikuni flatslides, but standard airbox, cams, valves etc. About 106 hp @ the rear wheel. Still not enough to keep with modern 600's on the straights - though they must be 50Kg lighter.
CMA rear wheel 18x2.5 (same size as standard but lighter) with a 120/90 Conti Classic Attack Road. Dymag front wheel with 110/90 BT45).
Standard calipers with a radial master cylinder.
Standard forks - last year at Cadwell I was dragging the alternator casing so I fitted some stiffer springs and Racetec emulaltors which has the raised the front end up a fair bit. Problem is, not enough dive now and felt like the front was trying to lock at times.
I've got a Metchamex arm as well. I don't think it makes any difference to the handling but has eccentric adjusters so with the axel at the bottom it increases ground clearance.
Brian
Brian
				Is Vic There
- big green bus
brian 1100 wrote:So now anyone else tempted to do the Classic Bike Trackday in August at Cadwell? You don't need a modern bike to have fun.
Brian
The metchamex is so much better than standard. I could get my standard swingarm to flex more than an inch, just had it powder coated then was mortified to notice a scrape both side from the rear peg bolts half an inch away both sides (yes new bearings stevew
Users browsing this forum: No registered users and 0 guests
