ZXR front end
Robw
ZXR front end
#1 PostAuthor: Robw » Thu Oct 25, 2007 7:13 am
Hi, how easy is it to fit a ZXR 1100 front end to a ELR frame,
Cheers Rob
steve rees
ZRX front end onto ELR frame
#2 PostAuthor: steve rees » Thu Oct 25, 2007 6:57 pm
Rob,
It should not be too hard--i have fitted a Zephyr 750 front end onto one of my Z1000A2's
the way i went about it was to measure the following items:-
1) the internal diameter of the recess for the top and bottom bearings when they are fitted in the steering head.
2)measure the depth of the recess also so you dont get bearings that are too thick
3) measure the effective steering stem length from your ELR between the bearings
4)measure the dia of the stem at the bearing seat location at top and bottom of the stem
having got the dims noted, i then went to my local bike shop (well went to Pitstop in Lowton near Leigh-- not exactly local but recommended by Z-power and good guys) with a sketch of what i had "before" and "planned" and Tony went through his bearings catalogue and found bearings that fitted the sizes i wanted and then they were ordered up and delivered a couple of days later.
then fit bearings and yolsk and the rest is easy (ish)
i hope i haven't missed anything out
oh!--one thing i dont know if i was just lucky or what but the steering security lock stops on the Z1000 frame matches the steering lock stops on the bottom yolk of the zephyr--lucky or what?? you might have to fabricate your own lock stops but you might get lucky too.
If you want more info then just ask
regards
Steve Rees
Reecy m21
#3 PostAuthor: Pigford » Thu Oct 25, 2007 7:20 pm
Good advice there :wink:
If that ain't gonna work, you could get hold of a cheapo standard bottom yoke for the ELR frame, then you can use the stem and maybe able to get the ZXR yoke top + bottoms adapted to fit :?:
I've got GSXR USD forks on me Z1000A2, but done the easy (expensive) route.
A set of 1-off billet yokes made up. You'll be looking at a minimum of ?450 if u can find a local engineers :shock:
Goodluck
Robw
#4 PostAuthor: Robw » Sun Oct 28, 2007 3:21 pm
Gents, thanks for the information, now off to find a front end.
Rob
steve rees
ZRZ1100 forks and yolks on ebay
#5 PostAuthor: steve rees » Sun Oct 28, 2007 7:41 pm
ob,
there is a set of forks and yolks for a ZRX1100 on flea bya at present
they are in Wigan
worth a bid by you ----they havent got any one interesetd yet by the look of things
regards
Steve Rees
Reecy m21
steve rees
spelt your name rong
#6 PostAuthor: steve rees » Sun Oct 28, 2007 7:42 pm
Rob (with an R),
sorry 'bout that type too quickly sumtimes
regards
steve rees
Reecy m21
Robw
#7 PostAuthor: Robw » Fri Nov 02, 2007 6:18 pm
Hi gents, I have been away on a course, so have missed the forks, although there are a set of yolks, which I have my beady eye on at the moment.
Regards Rob
kawaman21
#8 PostAuthor: kawaman21 » Fri Nov 16, 2007 9:04 am
hi robnw
i fitted a zrx front end to my z1100r a few years ago.
zrx yokes fitted with no mods other than cutting off the steering lock bracket on the headstock,bearings are the same and stem height is perfect
i used zrx12 yokes, with zrx11 forks,zx7r wheel(same as zrx),zx9 discs.310mm and nissan 4 pots from a j,k,l,m 750/1100 gsxr
all just bolts on easy.
rickman CRR
#9 PostAuthor: rickman CRR » Fri Nov 16, 2007 10:32 am
kawaman21
#10 PostAuthor: kawaman21 » Fri Nov 16, 2007 10:53 am
i cannot tell a lie,yes it is.
rickman CRR
#11 PostAuthor: rickman CRR » Fri Nov 16, 2007 1:11 pm
Its nicely done. Thinking about going the same route with mine. Do the flat slide mikunis cause any running problems?
Robw
#12 PostAuthor: Robw » Fri Nov 16, 2007 2:00 pm
Hi, cheers for the info, I am picking up a ZRX 1100 front end tomorrow and I should have the yolks by next weekend. The swinger is away getting a spacer machined and fitted. As soon as I have them fitted, I will start posting the pics in the Project section.
Cheers Rob
kawaman21
#13 PostAuthor: kawaman21 » Fri Nov 16, 2007 3:18 pm
i have 34mm flatslides
they were a bit rich to begin with
but that could have been me getting used to accelerater pumps :oops:
power is good, no flatspots,not had it on a dyno
but with standard carbs it was putting out 96bhp
at the back wheel,and i feels more than that now
sound good too :D
not used it much in the last couple of years
been sidetracked with a zx7
and now my marriage is up the creek
life is a bit complicated at the mo :(
