I seem to remember seeing the spool with paper on it assembled, called a filter, on eBay... Never followed it up!
[/URL]
[/URL]
RGH wrote:Garn l use air filter foam the universal stuff you buy in sheets that you soak in oil.
l have a NOS Silencer if you need measurements, yours looks a bit saggy.
l.ve always wondered about these A4 filters, pic looks like its for silencer but discription indicates convential air filter replacement, which is not correct for A4.
http://m.ebay.com.au/itm/370921424990?nav=SEARCH
Z903 wrote:I've always used ironing board foam...around 6mm thick usually Green or Cream colour, and probably relatively heat proof....I never had my A4 blow up at any rate.
