Z900-A4 Air-box silencer
Garn 1
#1 PostAuthor: Garn 1 » Tue Apr 29, 2014 10:48 pm
Who knows what (sound) insulation material goes around the spool in the air-box silencer pictured below? Seem to think it was foam rubber, could be paper?
I seem to remember seeing the spool with paper on it assembled, called a filter, on eBay... Never followed it up!
Image[/URL]
wayno
#2 PostAuthor: wayno » Wed Apr 30, 2014 3:40 am
seem to remember a post about this a while back, someone used a flameprook material/foam
G
#3 PostAuthor: G » Wed Apr 30, 2014 5:57 am
I thought it was foam too. Are you knocking one up Garn ?
Garn 1
#4 PostAuthor: Garn 1 » Wed Apr 30, 2014 7:21 am
G, I'm just supplying the dimensions and someone else decided to make one... If it works, i get his know-how and proceed with one myself.
I could imagine it being a fire hazard if soaked in fuel!
Z903
#5 PostAuthor: Z903 » Wed Apr 30, 2014 9:10 am
I've always used ironing board foam...around 6mm thick usually Green or Cream colour, and probably relatively heat proof....I never had my A4 blow up at any rate. :lol:
#6 PostAuthor: z1bman » Wed Apr 30, 2014 10:33 am
high density closed cell foam is what is used
RGH
#7 PostAuthor: RGH » Wed Apr 30, 2014 11:33 am
Garn l use air filter foam the universal stuff you buy in sheets that you soak in oil.
l have a NOS Silencer if you need measurements, yours looks a bit saggy.
l.ve always wondered about these A4 filters, pic looks like its for silencer but discription indicates convential air filter replacement, which is not correct for A4.
http://m.ebay.com.au/itm/370921424990?nav=SEARCH
Wayne1960
#8 PostAuthor: Wayne1960 » Wed Apr 30, 2014 11:59 am
Garn
I will have the mock up made shortly and will update you with some more pictures.
Bike now finished what a joy!
wayno
#9 PostAuthor: wayno » Wed Apr 30, 2014 4:44 pm
RGH wrote:Garn l use air filter foam the universal stuff you buy in sheets that you soak in oil.
i fell for the "looks like the silencer filter" after a few beers. doesnt fit the silencer and also dont fit the standard airbox. they are round so will not fit,
Garn 1
#10 PostAuthor: Garn 1 » Wed Apr 30, 2014 5:08 pm
Does any one have the dimensions of that "Hi-Flow" [HFA2901] air filter shown in the above eBay sale.
The dimensions of the steel spool in my photo (post #1) are 94mm outside rims dia and length is 158mm and bore is 60mm dia.
That EBay, Z900 -A4 item, is it what it states? both RGH & Wayne say..No!...
Z1Bman will know!
PS. For RGH, the outside rubber is a bit sloppy, it stiffens up when the spool is inside... Just like mine!
jimmock
#11 PostAuthor: jimmock » Wed Apr 30, 2014 5:31 pm
Z903 wrote:I've always used ironing board foam...around 6mm thick usually Green or Cream colour, and probably relatively heat proof....I never had my A4 blow up at any rate. :lol:
How the hell did you get that below the seat???
Jimmock. :wnkr
I hate people I don't like !
G
#12 PostAuthor: G » Wed Apr 30, 2014 5:45 pm
Good luck with it Garn, keep us updated
#13 PostAuthor: z1bman » Wed Apr 30, 2014 5:47 pm
the filter on e bay is not from any of the 900 series
z1/a/b filter
z900 a4 model
Wayne1960
Engine turnover
#14 PostAuthor: Wayne1960 » Wed Apr 30, 2014 8:23 pm
Got very impatient and still got my carbs to fit but couldn't stop myself from pressing the start button.
I have been kicking it over since filling with oil but my patience got the better of me tonight.
It sounded like a dream just spinning and thumping at the carb outlets.
The red oil light cam on but I guess that would be normal.
I'm not intending to make a habit of it but just wanted re assurance it's ok to do.
Suppose I should have asked first but thought I'd better check.
Wayne1960
#15 PostAuthor: Wayne1960 » Wed Apr 30, 2014 8:24 pm
Sorry meant to set up a new post for that!
