not turning over
jez1100r
not turning over
#1 PostAuthor: jez1100r » Sat Apr 26, 2014 4:43 pm
z1100r will not turn over starter circuit relay clicking starter rely /solinid not doing anything .also horns not working all other electrics working ok
Charlie
#2 PostAuthor: Charlie » Sat Apr 26, 2014 6:16 pm
Check the voltage in the battery. If it is not 12.8volts or more, the battery needs charging.
Mark Tiller
#3 PostAuthor: Mark Tiller » Sat Apr 26, 2014 6:19 pm
Have you checked all the fuses, not just visually?
if you out a thick screwdriver across the solenoid terminals does it spin over then?
jez1100r
#4 PostAuthor: jez1100r » Sat Apr 26, 2014 6:31 pm
Mark Tiller wrote:Have you checked all the fuses, not just visually?
have not tried that what does it mean if it does turn over .put a new fuse in .old one looked ok
#5 PostAuthor: Pigford » Sat Apr 26, 2014 6:48 pm
If its "clicking" power is getting to the solenoid - but maybe not enuff available for the starter motor.
As mentioned, check battery voltage/condition. Put lights on then try starter - see if they dim a lot.
Check starter main power lead connections too :!:
jez1100r
#6 PostAuthor: jez1100r » Sat Apr 26, 2014 7:03 pm
solenoid is not clicking relay is
paulmceleney
Chunks
#7 PostAuthor: paulmceleney » Sat Apr 26, 2014 8:04 pm
IF THE BIKE USE TO START WITH NO TROUBLE I WOULD CLEAN ALL BATTERY TERMINALS AND EARTH LEADS AND CHECK BATTERY LEVEL IS CORRECT AND FULLY CHARGED .SOUND LIKE IF THE BIKE HAS BEEN SITTING OVER THE WINTER AND NOT STARTED YOU MIGHT NEED A NEW BATTERY IF ITS NOT BEEN KEPT CHARGE OVER THE WINTER
jimmock
#8 PostAuthor: jimmock » Sat Apr 26, 2014 8:19 pm
What about jump leads off your car??
Jimmock. :wnkr
I hate people I don't like !
