Tyre fitting
wilsonsjw11
Tyre fitting
#1 PostAuthor: wilsonsjw11 » Sat Apr 26, 2014 11:48 am
After a new tyre has been fitted to rim what is the best way to stop it 'grabbing' the rim deflate it and apply soft soap?
Regards
Steve
#2 PostAuthor: z1bman » Sat Apr 26, 2014 12:06 pm
there is not much you can do about the tyre sticking to the rim you have to be careful what you use as most soap / washing up liquid & such have chemicals in them that will corrode the rim & anything too slippery will cause the tyre to creep on the rim.
http://www.ebay.co.uk/itm/Pro-Clean-Tyr ... 461e32e9bf
