Twin Disc Conversion
G
#1 PostAuthor: G » Tue Apr 22, 2014 6:45 am
Hi, When converting to twin discs is the domed dust plate on the r/h/ side of the bike replaced with an identical flat one as per l/h side and is the orig finish chrome . Bike is imported a4 Cheers G
tlc
International Rep
#2 PostAuthor: tlc » Tue Apr 22, 2014 6:53 am
If you mean the inner "pad retainer" it is the same and the finish should be BZP.
Asphalt Cowboy
G
#3 PostAuthor: G » Tue Apr 22, 2014 7:06 am
Thank you tlc.The part I am referring to is 9.5 cm diameter with the 4 holes, the disc tab washers fit on the outside of that.It is described in the parts book as a dust cover41012-14. On the right at the moment is a domed version of the same thing which obviously wont fit with twin disc set up that is why I was wondering if you fit 2 l/h ones when converting.
tlc
International Rep
#4 PostAuthor: tlc » Tue Apr 22, 2014 8:08 am
Photo shows what you have and what you need. The cover is for sale if you need it.
Asphalt Cowboy
G
#5 PostAuthor: G » Tue Apr 22, 2014 11:36 am
Thanks tlc .I have two left hand covers actually so ok there. Can you expand on the finish please.I take it to be a bright nickel plate ? and not chrome
tlc
International Rep
#6 PostAuthor: tlc » Tue Apr 22, 2014 4:10 pm
No it's chrome.
Are you sure two left handers will work?
Asphalt Cowboy
#7 PostAuthor: ADRIAN H » Tue Apr 22, 2014 6:05 pm
The one on the right should be flat. The left one is raised to cover the speedo drive.
G
#8 PostAuthor: G » Tue Apr 22, 2014 6:11 pm
Thanks Adrian, need a right side one then
tlc
International Rep
#9 PostAuthor: tlc » Tue Apr 22, 2014 7:15 pm
These are correct for a twin disc.
Asphalt Cowboy
tlc
International Rep
#10 PostAuthor: tlc » Tue Apr 22, 2014 7:18 pm
ADRIAN H wrote:The one on the right should be flat. The left one is raised to cover the speedo drive.
The one on the left, speedo side, is flat whilst on the right it is raised to cover the spacer.
Asphalt Cowboy
G
#11 PostAuthor: G » Tue Apr 22, 2014 7:21 pm
Okm thanks, how much do you want for r/h side one please
#12 PostAuthor: ADRIAN H » Wed Apr 23, 2014 9:01 pm
Having a bad day, (or is it week) I will get my coat. :lol: :oops: :oops: :oops:
G
#13 PostAuthor: G » Wed Apr 23, 2014 9:21 pm
Still appreciate you trying to help :D
