Z650 into 810 project
Crofty
#211 PostAuthor: Crofty » Wed Apr 16, 2014 11:10 pm
Finally got bike all back together and running, new bearings, oil pump, filter and relief valve, new clutch housing (old one I had rebuilt with rubbers from a guy in OZ and the rubbers appeared to be breaking down), this may of been from the higher temps when oil starved, but taking no chances.
Took the opportunity to do some odd jobs while off road including having Venhill make some throttle cables as I had made some with screw on barrel ends which I did'nt trust not to fail while miles fom home.
Replaced the rear sprocket bolts with drilled socket heads so I can wire them in place.
ollie
#212 PostAuthor: ollie » Thu Apr 17, 2014 3:42 am
Glad you managed to sort it out Jim ,looks excellent pal :wink:
Flying Tiger
Ted's Biatch
#213 PostAuthor: Flying Tiger » Thu Apr 17, 2014 7:09 am
Looking real nice Jim!
#214 PostAuthor: Pigford » Thu Apr 17, 2014 11:46 am
Beeeeewetiful :P
shrekward
#215 PostAuthor: shrekward » Wed Apr 30, 2014 7:58 pm
wizard
