Hi guys, my z1 has a sticking clutch.
When I try to put it into 1st, it's like I haven't pulled the clutch in - it just stalls.
I know the trick of freeing it off with the kick start before starting the engine but even with the clutch pulled in, the engine turns over when I kick it over.
Any tips as to what the problem may be?
It hasn't been used for about 6 weeks and obviously not much over winter. Last time I used it, it was same but after a couple of goes it freed itself and all seemed ok.
Any tips gratefully appreciated.
Clutch that won't let go!
- steve bowdler
I put mine on the center stand and with it running in gear hold the clutch lever in and stand on the back brake. It takes a few goes and it doesnt put to much force on the gears, and like steve says the elastic band trick works.
Z1b, z900 A4, zxr750 m2, zrx1200
Z1000 (2003) lawson thingy,
Z1000 (2004) z1b lookalike ,
Z1000j lawson race bike,
Gsxr750H.
Gsxr750H.
