Rectifier needed ASAP, got one now, thanks TLC
- Mark Tiller
Bike let me down this AM....Anyone close to Leighton buzzard got a std rectifier i could buy or borrow or a combined unit they havent yet fitted, cheers...07962421462
- Regular Poster
- Mark Tiller
- Mark Tiller
I had an interesting conversation with a very experienced mechanic the other day.
It seems that fitting the newer gel type batteries is not advisable for our older bikes. The explanation being that our generators simply don't output enough for this type of battery.
He has seen it many times before and said they usually fail after a short period, 3000 miles or so.
Asphalt Cowboy
Mark, it's usually the regulator that breakdown on these older Kawasaki's. So, before wrapping up, check the voltage across battery at say 3000RPM.
TIC that's interesting. I just had a 12month old "Motobat" fail on me!
I thought the old Z1-Z1000's had alternators that could run a workshop?
RegardZ
RegardZ
- Mark Tiller
- Mark Tiller
KeithZ1R wrote:When you get it fitted Mark I for one would be very interested on the results you achieve if you don't mind
It arrived today, its a PMC one and came with a whole page of instructions, as a fluent reader of Japenese I had no problems
Mark Tiller wrote:KeithZ1R wrote:When you get it fitted Mark I for one would be very interested on the results you achieve if you don't mind
It arrived today, its a PMC one and came with a whole page of instructions, as a fluent reader of Japenese I had no problems...easy to connect with the correct type of plug and bolts where the old rectifier was, works fine, voltage across the battery back to normal...Happy Days
be interested in anybody's experience with the electrex world units ?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
