Harris Magnum I
HowieD wrote:looking and sounding very good.
My camera phone (and filming ability) is very poor - but the motor sounds really good
Only problem is the cam cover is weeping - think I just stuffed it back on with the old gasket when I set the valve clearances 18 months ago
Its booked in for an MOT Monday week
Some more video...... taken today:
Pigford wrote:Magnum1 wrote:How much was the battery? I can only see them for £190 when I search for a YB16
£119 delivered.....
http://www.ebay.co.uk/itm/JMT-Lithium-I ... 2333708125
I got one for a Yamaha XV 1700 Road Star Warrior 5PX4 (VP14E)
Cheers!
- firyembers
- Custard Creem
I purchased one of these MBTX20U from LM spares Hereford(Raw Power) which seems to have no stock,and was about £70 odd 2 yrs ago.
http://www.impactbattery.com/motobatt-m ... ttery.html
http://www.ebay.co.uk/itm/like/17094200 ... e&lpid=108
The first link is a list this battery will replace
The 2nd link from eSpares is £78.00 inc postage better than £100 plus.
Beén no bother for me,although it's spent most of it's time on a trickle charger.
Hope that helps
Hope that helps
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
firyembers wrote:I purchased one of these MBTX20U from LM spares Hereford(Raw Power) which seems to have no stock,and was about £70 odd 2 yrs ago.
Hope that helps
The LITHIUM battery is a different animal - it weighs bugger all compared to GEL or ACID batteries
Fitted some filters on the Z1R 28mm carbs....
Pigford wrote:firyembers wrote:I purchased one of these MBTX20U from LM spares Hereford(Raw Power) which seems to have no stock,and was about £70 odd 2 yrs ago.
Hope that helps
The LITHIUM battery is a different animal - it weighs bugger all compared to GEL or ACID batteries![]()
Do you have to have a special charger for the Lithium batteries ? and are they completely sealed (no maintenance) ?
Checked out electrics - battery is good - all charging okay too!
Wired up the Acewell speedo - just got neutral & oil pressure lights, but does have rev counter with RPM gear change light too.
Fitted the speedo pick-up onto the sprox cover with the magnet on the drive sprox. The final drive ratio is 2.3:1, so took the front wheel circumference and divided by 2.3 to give the figure (600mm) to feed into computer...... will see how far out it is after a proper "roadtest".
Couple more shots of it in daylight......
Ran it around the yard at work - all seems good - ready for MOT next week
Looking good, them front brakes look the part, glad I bought some from padders!
- firyembers
- Custard Creem
I fancy that with undertail exhausts,been looking at the style for my gpz for ages course finding it is sommat else,more like a self custom build
But a nice moto all the same..just have fun regardless with it it.
Is Vic There wrote:Looking good, them front brakes look the part, glad I bought some from padders!
They are fookin' awesome - if anything, a bit "over-braked" me thinks
Thanx for the positive comments - although its all down to personal taste - but thats what its all about in my book
- firyembers
- Custard Creem
Not overbraked at all,just imagine all those stoppie stunts you can pull at your next exhibition,even a comment from the passenger." I was expecting to fall off the back not the front...Heh heh
