Wanted Urgent Z1000H exhaust valve or APE Manley one 31mm
Padders
#1 PostAuthor: Padders » Sun Mar 30, 2014 6:38 pm
Hi I have a bent exhaust valve on my Z1 head that needs replacing but the valves are oversize 31mm. Martin has been checking and H exhaust valves are 31mm if anyone has a decent one for sale. Also APE and Manley do 31mm ones if any one has one for sale. This is the largest you can go on the standard seats and the bike is VOR until I can source one.
PUM 13
Robw
#2 PostAuthor: Robw » Sun Mar 30, 2014 6:41 pm
Are they the same as the Z1000J valves?
Rob
Padders
#3 PostAuthor: Padders » Sun Mar 30, 2014 6:42 pm
No Rob they are 32mm which is a shame as I have a J head in the garage.
PUM 13
Robw
#4 PostAuthor: Robw » Sun Mar 30, 2014 6:44 pm
Thats a shame as I have oversize ones left over from my last build.
Rob
Padders
#5 PostAuthor: Padders » Sun Mar 30, 2014 6:59 pm
I may be wrong Rob as just had pm saying Z1000H valve is same as the J so need to check the size.
PUM 13
#6 PostAuthor: z1bman » Sun Mar 30, 2014 7:01 pm
Padders
#7 PostAuthor: Padders » Sun Mar 30, 2014 7:03 pm
Thanks for that just need someone to confirm the H one is 31mm and I can press the buy it now button.
PUM 13
#8 PostAuthor: z1bman » Sun Mar 30, 2014 7:13 pm
i thought the z1000 h had 32mm exhaust valves same as gpz1100???
Padders
#9 PostAuthor: Padders » Sun Mar 30, 2014 7:44 pm
Some say 31mm such as Z Powers site and others say its 32mm just trying to find out before splashing out on a stainless APE one or Manley.
Cheers for looking
PUM 13
#10 PostAuthor: z1bman » Sun Mar 30, 2014 8:18 pm
the part no z power have for the z1000h exhaust valve 12005-1011 is listed as the same valve as a z1000j & gpz1100/b1/b2 which are 32mm ?
Padders
#11 PostAuthor: Padders » Sun Mar 30, 2014 8:28 pm
Yes but if you look at the z1000 valve part it says the H is 31mm
https://www.z-power.co.uk/merchantmanag ... cts_id=674
PUM 13
prowlerz1
#12 PostAuthor: prowlerz1 » Sun Mar 30, 2014 8:30 pm
Hi guys Zpower state z1000h1 only has 31 mm valve
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
#13 PostAuthor: z1bman » Sun Mar 30, 2014 8:40 pm
in your previous post you have stated that the j model has 32mm valve & in this listing from z power they state the z1000h uses the same valve & list the same part no. so have z power made a mistake in saying the z1000h valve is 1mm bigger & is 31mm & should be 32mm
https://www.z-power.co.uk/merchantmanag ... ts_id=1103
#14 PostAuthor: zed1015 » Mon Mar 31, 2014 9:50 am
Beware ! J valves are also SHORTER so make sure you get the right one.
When fitting o's valves, the larger heads need sinking in the seats to retain valve to valve clearance.
It is common practice to use the shorter J valves to retain correct valve stem height.
Big Fluff
#15 PostAuthor: Big Fluff » Mon Mar 31, 2014 11:51 am
I may have a 31mm exhaust valve... I got quite a lot of spares from S+S Performance with the purchase of the Saxon many years back.
The exhaust valves are all oversize on the turbo heads and I'm sure I may have some spare valves.
Will take a look this eveing.
Regards, Will
