Just finished cleaning up the rota coil and notices one if the wires had split. It is one of the 3 that connect to the coil.
I managed to strip back the material sheathing and plastic coating to expose the wire which I twisted and solders back together.
I guess the wire can get hot and wanted to know if soldering was an acceptable fix and what can I use to insulate/ cover the repair.
Thanks in advance.
Rota Coil
Small Tubular inline crimps and solder are good just cut the thick insulation off and replace it with self amalgamating tape when your happy you have a good joint
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- steve bowdler
Wayne1960 wrote:Hi Keith
What is self amalgamating tape?
http://en.wikipedia.org/wiki/Self-amalgamating_tape
