13mm Under Bucket Shim Swap Shop. Now Under New Management.
Crofty
#16 PostAuthor: Crofty » Sun Mar 23, 2014 8:47 am
Hi GB, not sure if there is anyone in the club that could offer that service. I had SEP Kegworth tip some valves for me. Hence there is an envelope on its way to you with at least on 2.15 shim in. I need stuff in the range of 2.65 to 2.80 now.
Crofty
#17 PostAuthor: Ginger Bear » Sun Mar 23, 2014 8:54 am
Crofty, many thanks for your kind donation, that's the second one this week. :shock: Adrian H has also sent me his significant stash, as he no longer needs them. :up
.......... I'm beginning to feel like a 'charity case' :rir
# 104
Crofty
#18 PostAuthor: Crofty » Sun Mar 23, 2014 10:43 am
Donation!!!
I need to swap for larger shims GB!!!! Just mentioned there are some smaller sizes in the ones I have posted including a 2.15, you should get them on Tuesday morning.
After having the tips done, I don't have anything close to try in to get a reading to work from, I have sent 16 shims in to get 16 back and go through the trial fit and measure process.
Crofty
#19 PostAuthor: Ginger Bear » Sun Mar 23, 2014 10:58 am
My mistake! :hys
I'll try and get your shims out the same day...... All 16 of em. :wink:
# 104
#20 PostAuthor: Ginger Bear » Mon Oct 17, 2016 3:53 pm
After some negotiating with Steve Parr & Karen this weekend, Karen has agreed to take over this scheme.
Please contact Karen (Muckmagnet) for your 13mm shims.
# 104
kz900B1
#21 PostAuthor: kz900B1 » Mon Oct 17, 2016 7:28 pm
Musht', be a schimackover :oops:
colinKZ900B1
#22 PostAuthor: Al » Mon Oct 17, 2016 9:00 pm
Thank you.
