Hi GB, not sure if there is anyone in the club that could offer that service. I had SEP Kegworth tip some valves for me. Hence there is an envelope on its way to you with at least on 2.15 shim in. I need stuff in the range of 2.65 to 2.80 now.
Crofty
13mm Under Bucket Shim Swap Shop. Now Under New Management.
Donation!!!
I need to swap for larger shims GB!!!! Just mentioned there are some smaller sizes in the ones I have posted including a 2.15, you should get them on Tuesday morning.
After having the tips done, I don't have anything close to try in to get a reading to work from, I have sent 16 shims in to get 16 back and go through the trial fit and measure process.
Crofty
Crofty
