Borrow only - J/R/GPz valve clearance (shim) tool 57001-113
Big Fluff
#1 PostAuthor: Big Fluff » Fri Mar 21, 2014 9:44 am
Can anyone loan me the above valve clearance tool for the J/R/GPz range.
The club only has the tool 57001-109 for the round shape head and I will need to adjust the valve clearances on my ELR rep next week after it's bed in/settled down.
I will make a new tool using the loaned one as a template and post a fully detailed drawing on the forum like I did for the early type.
I donated about 50 shims to the club a couple of years ago.
Many thanks, Will
#2 PostAuthor: Al » Fri Mar 21, 2014 5:51 pm
Will i used the tool which i sent you previously when i had shim on top j head.
Now it is shim under there is no tool!!!
WHY?
#3 PostAuthor: z1bman » Fri Mar 21, 2014 5:59 pm
if the shim is on top of the bucket use 57001-113 if its the small z650 type shims you will have to remove the cam
Big Fluff
#4 PostAuthor: Big Fluff » Fri Mar 21, 2014 8:09 pm
OK let me clarify.
It is a standard J/R/GPz head with shim on top.
I already have the factory tool for the Z1/A/B/900/1000A1/2. This will not fit around the outside of the cyl head so I cant hold the folllower.
Obviously there must be some difference otherwise Kawasaki wouldn't quote a different tool would they :?:
Keefleaf
#5 PostAuthor: Keefleaf » Sat Mar 22, 2014 4:55 pm
I've got 2 types.
Check part no; stamp when I get back.
Keefleaf
#6 PostAuthor: Keefleaf » Sat Mar 22, 2014 10:24 pm
Hi Will, got 57001-113 and 57001-501.
I'll send Email Pic.
Users browsing this forum: No registered users and 4 guests
