wiring loom z1000st
Road Runner
wiring loom z1000st
#1 PostAuthor: Road Runner » Tue Feb 25, 2014 5:32 pm
Hi All, I've just got back in the fold and bought a rather tired Z1000ST, the wiring looks past it's best! All sorts of connectors and taped and cut wires etc! Does anyone know where I can get a replacement wiring loom from?
Thanks :?:
Ride Safe!
#2 PostAuthor: PAULJAC47 » Tue Feb 25, 2014 5:56 pm
Be surprised if you will get one,strip off the old loom and use it as a template on a board to make a new one up..Paul J
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Tue Feb 25, 2014 5:56 pm
z-power do a1/a2 looms new, not sure how different it would be, but worth a call.
Road Runner
#4 PostAuthor: Road Runner » Tue Feb 25, 2014 6:12 pm
Ok thanks will give them a call tomorrow. It's gotta come off anyway so I'll have a good look at it when it's off.
Ride Safe!
weaver
#5 PostAuthor: weaver » Tue Feb 25, 2014 6:20 pm
you may be better off working thru it and refurbing it,you can buy the proper jap style connectors off ebay and then retape it
#6 PostAuthor: Ginger Bear » Tue Feb 25, 2014 7:34 pm
I've just discovered this lot via this forum;
http://stores.ebay.co.uk/autostarshop/
I can report that the service is excellent.
Also used these for years;
http://www.vehicle-wiring-products.eu/V ... mepage.php
Service is also excellent, but the 'phone manner' could do with a bit of work. :??
# 104
gpjes
Wiring loom z1000st
#7 PostAuthor: gpjes » Fri Feb 28, 2014 7:34 am
Heyup me's had same problem don't forget ours have early electronic ign so loom will be different though should be same as mk11 I replaced all the blue and red spade and bullit connectors with items from kojay electrical do spend time going through their listings, it's worth it, they also do a great laminated A5 size wiring diagram in correct colours makes life a bit easier. Get the correct connector tool as well, I cocked a couple of joints up till I bought one, remember the part that most people forget, the bit that flexes from frame to handlebars does get metal fatigue over the years, might be teaching you how to suck eggs, but been there and done it, fault findings a real teewat :roll:
More Smiles Per Mile
big green bus
#8 PostAuthor: big green bus » Fri Feb 28, 2014 8:45 pm
I got a new MK2 loom from Zpower
jphaynes669
#9 PostAuthor: jphaynes669 » Fri Feb 28, 2014 8:52 pm
Give john browse a ring, 01978, 355556. He may have a decent used loom.
Think the mk2 loom and the st looms will be different, due to equipment and component positioning around the bike.
Jeff.H
#10 PostAuthor: z1bman » Fri Feb 28, 2014 10:26 pm
Road Runner
#11 PostAuthor: Road Runner » Sun Mar 09, 2014 12:02 am
Thanks guys, it's off and not too bad really. So I think it can be sorted with a little time etc. Electrics not my strong point but I'll have a go!
Ride Safe!
