PLASTIC WELDING - Anyone know more?...
MaineKZ
#1 PostAuthor: MaineKZ » Wed Oct 17, 2007 7:39 am
I've got an original 73 side panel with good original paint which has a smallish but 'clean' fracture in the plastic.
Anyone know anyone who can 'weld' up this type of plastic successfully?
Also, can it be repaired 'invisibly' on the inner face so as not to damage the painted surface? Be a shame to lose the original paint.
Cheers - Chris
steve f
#2 PostAuthor: steve f » Wed Oct 17, 2007 3:16 pm
NO YOU WILL MARK THE PAINT
big green bus
#3 PostAuthor: big green bus » Wed Oct 17, 2007 4:51 pm
use a soldering iron on the inside and push the plastic into the crack from sides like knitting try and find an old panel or something to cut a strip off to use as a filler rod. it must be off a bike to make sure you get the same type of plastic. i think it is ABS, but am not sure if you are carefull you will end up with a hair line crack on the front but no paint damage. the trick is to take your time.
bedlow1
#4 PostAuthor: bedlow1 » Wed Oct 17, 2007 5:54 pm
try tigwell williams coach works, just down the road from you in slough
01753 682176
Or if your brave try
http://cgi.ebay.co.uk/SEALEY-Plastic-We ... dZViewItem
steve f
#5 PostAuthor: steve f » Wed Oct 17, 2007 9:10 pm
knitting needles are very good as you can get different thickness
steve bowdler
#6 PostAuthor: steve bowdler » Thu Oct 18, 2007 6:32 am
Try Plastech Plastic Repair Kit Handy Pack (Product Code: 501867) from M&Ps very strong and toxic stuff :wink:
Pasc
#7 PostAuthor: Pasc » Thu Oct 18, 2007 6:56 am
steve f wrote:knitting needles are very good as you can get different thickness
:hys
Can you crochet as well Steve ?
jam
#8 PostAuthor: jam » Thu Oct 18, 2007 7:52 pm
If you can find it there's a product in some car auto shops called VersaChem plastic welding system, it's a two part epoxy based system and it's brilliant, I've rebuilt whole lugs and missing sections with it. Unfortunately it is no longer imported into this country from the states, so it may be hard to find, in fact if you do find any buy it all, it's about 4 quid a pack, as I'll have some off you. Failing that the Wurth system is virtually identical but a hell of a lot more expensive.
steve bowdler
#9 PostAuthor: steve bowdler » Fri Oct 19, 2007 6:15 am
If this is afore mentioned stuff http://www.amazon.com/Versachem-Plastic ... B0002JN5G0 $3.99 plus postage.
jam
#10 PostAuthor: jam » Mon Oct 22, 2007 10:08 pm
That's the stuff, it's absolutely fantastic kit. I've used it on loads of repairs and had no failures yet with it. I can't get it in the UK any more, as the importers can't bring it in due to kitemark packaging problems. If anyone can find a way of getting it into the UK I'd take as much as I can get hold of. It's easy to use and very similar to the Wurth system, but loads cheaper. it's very very strong and can be used for joining different types of plastic, which makes it ideal for one off body parts for streetfighters and suchlike. If anyone can get it let me know please.
jtreg
#11 PostAuthor: jtreg » Tue Oct 23, 2007 12:05 pm
M&P do Plastech Starter Kit at ?9.99 I have used it often and its great
Steve Cooke
#12 PostAuthor: Steve Cooke » Tue Oct 23, 2007 3:31 pm
Another good epoxy is Belzona which is very good and a lot less risk to paintwork than welding,the problem with welding is that if you apply enough heat to weld properly right through you will damage the paint, if you don't the weld will just be on the inside.
jam
#13 PostAuthor: jam » Mon Oct 29, 2007 1:25 pm
I've just ordered the Wurth plastic welding system, which I've used before and is brilliant, However it aint cheap, just the refills are a tenner or so, but when you weigh up the cost of a new panel, it more than pays for itself.
Gus
#14 PostAuthor: Gus » Mon Oct 29, 2007 6:30 pm
I just got this e-mail today regarding Versachem Plastic Weld
Dear Sir
I have been given your details by ITW in the US regarding your interest in Plastic Weld.
We have this product available in 28ml, 50ml and 400ml cartridges.
If we can be of any assistance please do not hesitate to let me know.
Kind regards
Warren Wilkinson
warren@bondloc.co.uk
01299-269914 direct line
