Weaver's ELR
weaver
#46 PostAuthor: weaver » Tue Jan 28, 2014 6:07 pm
been busy working on the bike this last week,got it running today :)
Its been off the road since October 2012,total strip for cosmetics,the top end was stripped,the barrels had a lot of fin damage so I obtained another set,sweated the liners out and swapped them over,had the top of the block skimmed as a couple of liners were very slightly proud.I also repaired a damaged fin on the head and replaced the valve stem seals.The bores were in spec and compression ok,the ring end gaps also ok so motor rebuilt with original rings.
The loom has been cleaned and retaped.
Loads of other things have been sorted as well along the way that would take to long to list,here's some pics.
Still plenty to do,need to decide if I am going to use original footpegs,the raask ones I had fitted prior to the strip or to make up some mounting plates for a more modern set of rearsets I obtained last year.
The body work is still to be sorted and I would like to get the pipe ceramic coated, I also have a stage 3 dynojet kit to fit.
Will post up again once some more notable progress is made.
garyd
#47 PostAuthor: garyd » Tue Jan 28, 2014 8:41 pm
Looking good.
Who did your Hydraulic Clutch conversion?
Is Vic There
#48 PostAuthor: Is Vic There » Tue Jan 28, 2014 8:43 pm
Nice job mate well done. :D
weaver
#49 PostAuthor: weaver » Tue Jan 28, 2014 8:55 pm
garyd wrote:Looking good.
a previous owner did the conversion,altho I had to sort out a couple of the threads with inserts,its a zrx1100 unit welded into the 1100r casing,works well
Is Vic There
#50 PostAuthor: Is Vic There » Tue Jan 28, 2014 9:08 pm
So that's basically a GPz1100 motor then? Just looks the same with the front mounts see I'm learning about all these mountings! :D
weaver
#51 PostAuthor: weaver » Tue Jan 28, 2014 9:14 pm
Is Vic There wrote:So that's basically a GPz1100 motor then? Just looks the same with the front mounts see I'm learning about all these mountings! :D
yes mate the 1100r used the unitrak motor
#52 PostAuthor: paul doran » Tue Jan 28, 2014 10:24 pm
looks ace
#53 PostAuthor: Al » Tue Jan 28, 2014 10:36 pm
Youve really turned that around it looks ace.
Whats going on with the tape on the Ramairs'??
Is Vic There
#54 PostAuthor: Is Vic There » Wed Jan 29, 2014 2:22 am
I reckon its to stop water draining from the highly polished tank and soaking into the foam, I had some stainless covers for my Z650C3. :wink:
jimmock
#55 PostAuthor: jimmock » Wed Jan 29, 2014 3:39 am
BLACK spark plugs, very unusual !!
Only kidding, I'm impressed !!
Jimmock. :wnkr
I hate people I don't like !
Richard L
#56 PostAuthor: Richard L » Wed Jan 29, 2014 7:19 am
That looks really good , what paint did you use on the engine and what is the plan for the bodywork ?
Richard
scott
Junior Section leader
#57 PostAuthor: scott » Wed Jan 29, 2014 8:13 am
Weaver....i noticed you have an ABBA stand and have the correct fixings....did you buy the fixings from ABBA or did you make your own? I need some for my A2 and it would be nice to know if i can purchase or have to make them.
weaver
#58 PostAuthor: weaver » Wed Jan 29, 2014 8:26 am
zorded wrote:Youve really turned that around it looks ace.
the tape is there to reduce the air flow as I havent fitted the dynojet kit yet,wanted to prevent it running too lean
weaver
#59 PostAuthor: weaver » Wed Jan 29, 2014 8:29 am
jimmock wrote:BLACK spark plugs, very unusual !!
:D :D
they were special Kawasaki fitment circa 1985,I can sell you a set for a few hundred pounds if you like
weaver
#60 PostAuthor: weaver » Wed Jan 29, 2014 8:34 am
Richard L wrote:That looks really good , what paint did you use on the engine and what is the plan for the bodywork ?
Richard
The engine paint is Simoniz tough black as recommended on here,the paint work will be meanest green,nothing to far from original
Users browsing this forum: Bing [Bot] and 13 guests
