Calipers and Brake line
when i connect the metal brake hose to the calipe should it tighten up so the mateal doesnt spin? when its tight i can still move it! should there be any sort of seal? nothing came with the metal hoses.
Bike now finished what a joy!
Redbeard
dont you just love it when someone tells you something you realy want to hear.
Thanks for that. Not sure how it doesnt leak when you think of the pressure your pushing in but ill take your word on it.
Hi Steve
Interior nipple? I have tonight removed the metal break line and checked the calliper inside the threaded hole. The bottom of the hole looks like it is slightly cone shaped and there is a hole in the middle which looks clean enough.
Threads are clean also but when I put the boreal line back in and tight there is a good 1mm slack movement and when I blow down the tube air escapes between the threaded bolt and the tube.
Doesn't feel right to me
Any advise?
Any advise?
your brake pipe should look like this
it might be that the brake pipe nut is not screwing far enough in to the caliper to compress flared end of the brake pipe
