z1000 mk2
- big green bus
z1000 mk2
Does anybody know what battery I can fit to a z1000mk 2 that has a bit less height. the mods I am working on required I moved the battery box up so the battery will now touch the airbox intake pipe.
You need 14 amp for the starter.
The equivalent Motobatts are smaller .
Most of the ebay listings state the L/W/H measurements so should be easy enough to find one that fits.
If you can't find one small enough there's always those Shorai Lithiums which most definitely will fit but you want to be sitting down when you see the price.
snotie1965
zed1015 wrote:You need 14 amp for the starter.
If you don`t mind me asking ? how much was the "Shorai lithium" ? and also the charger ?
snotie1965 wrote:zed1015 wrote:You need 14 amp for the starter.
Are you sitting down ?
They were £179.40 delivered from Carrot cycles in Lincoln.
Battery was £92.00 + vat etc on it's own.
Lots of different case sizes etc to choose from.
SEE HERE - http://www.carrotcycles.co.uk/index.php ... cat_id=217
- big green bus
neilbarrett
LTD Project
I was in a similar position and found a Motobatt MB10U did the job with the necessary CCA for gpz1100 engine. Well happy in the end. Gives the equiv of 14.5 Ah.
Good luck
Good luck
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
- big green bus
