Electrics
Electrics
Well put a new battery on my Z550 project today, all the bits work, lights, break light, indicators etc, engine turns over nicely, but no spark at the plugs, any of them, it has the electronic pick ups, ignitor etc, any pointers to check out, what is the most likely problem? ta
jphaynes669
Now then, I have checked all connections, I have replaced most, all seem ok, there is no side stand switch, its and american import, cheers JB, I do have 11.4 volts at the coils, I have put the ohm tester on the pickups, 450 reading on both, engine turns fine, all other electrics working, just no bloody spark
could it be either the regulator or the ingniter?
Right, I have done the check for voltage at the igniter, there are 4 wires. all show voltage except the black/yellow which is the earth, so power going in and out! the dowel pin is ok I only put it together recently. Could it be the battery, it is brand new yuasa, not had a trickle charge since filling, but showing 12 volts.
you can check the pulse with a multi meter but it is better to use a logic probe. the wires from the pick up coils should have a fluctuating voltage as the engine is spun over if you have a steady / constant voltage the pick up coils will be bad. the same applies to the output wires on the cdi
logic probe
http://www.rapidonline.com/test-measure ... obe-31049/
logic probe
