GPZ750R1 Oil Cooler
GPRD
GPZ750R1 Oil Cooler
#1 PostAuthor: GPRD » Thu Jan 16, 2014 3:44 pm
I'm having problems with getting an oil cooler that is useable, the problems I'm having are the threads are either stripped, or it leaks from somewhere else, but, my question is, if I blank the hose holes up on the engine temporarily, until I get a useable cooler, will that cause a problem with oil circulation?
What we got here, is failure to comunicate.
oldtimer
#2 PostAuthor: oldtimer » Thu Jan 16, 2014 5:16 pm
Have you looked at a cooler for a ZR750 Zephyr, probably the same, I wouldn't blank off the cooler personally, it is there for a reason.
steve.w
#3 PostAuthor: steve.w » Thu Jan 16, 2014 5:28 pm
dont blank them loop em together with a bit hose ..but as said its on for a reason :wink:
snotie1965
#4 PostAuthor: snotie1965 » Thu Jan 16, 2014 5:53 pm
I have a old one ,off a unitrack 11 ? if it would be any good let me know ?
I think i have some old hoses as well , i think they are the same ?
I am sure someone on this forum will know ?
GPRD
#5 PostAuthor: GPRD » Fri Jan 17, 2014 9:04 am
Thanks for the replies.
I was onl;y going to block it off temporarily, so I could getting it running properly while sorting the cooler.
I'm not sure about the GPZ1100 cooler, I've already had the frame powder coated, so I don't want to have to fit any new brackets, and it has different fittings to the 750, but it is an option, thanks.
oldtimer
#6 PostAuthor: oldtimer » Fri Jan 17, 2014 9:59 am
Do you have a picture and dimensions of the cooler and I will compare it to my 750 Zephyr cooler if it helps.
#7 PostAuthor: zed1015 » Fri Jan 17, 2014 10:19 am
You won't hurt the engine by disconnecting the cooler ( especially with our weather :roll: )
But DO NOT just blank off the take offs or you will cut off the oil supply and wreck your engine.
You MUST link the take offs with some hose so that the oil can still circulate.
steve.w
#8 PostAuthor: steve.w » Fri Jan 17, 2014 10:39 am
gpz 1100 is totally different ..also the hoses are aswell.. as these go over the cam cover and connect to the top of c/case .. think gt 750 is same as r .. ..i have some pipes if you stuck :wink:
KWACKERZ1
oil cooler
#9 PostAuthor: KWACKERZ1 » Fri Jan 17, 2014 1:33 pm
A mate of mine has one I'll pm you his number!
GPRD
#10 PostAuthor: GPRD » Fri Jan 17, 2014 2:59 pm
Thanks Steve, I bet you have!!!
Cheers Phil, it looks like I'm sorted now.
Thanks for the help people.
Users browsing this forum: Bing [Bot] and 22 guests
