MOT Questions on Custom Build
Royalratch
#1 PostAuthor: Royalratch » Fri Jan 10, 2014 11:39 am
Hi all.
can anyone help with this:
1) Do both front and rear brake need to have switches for brake light?
2) Do you need to have a kill switch - if so can it be 'hidden'
3) If you have keyless ignition (but push button starter) does the key fob transponder also act as kill?
Cheers in advance!
#2 PostAuthor: zed1015 » Fri Jan 10, 2014 11:51 am
1. Bikes pre 1986 need only one brake light switch and can be operated from either front or rear ( Post 86 need both front and rear brake switches if originally fitted)
2. A kill switch is not compulsory .
3. Haven't a clue about the key fob transponder.
Royalratch
#3 PostAuthor: Royalratch » Fri Jan 10, 2014 12:00 pm
Awesome!
Thanks dude.
I think I can wire my Motogadget to kill engine with swipe of transponder when engine is running.
Cheers.
#4 PostAuthor: zed1015 » Fri Jan 10, 2014 12:16 pm
I misread the last question.
Thought you meant cutting the main power from the key fob.
So.
3. Yes! those remote starters will start and then stop the engine.
z1000puddin
#5 PostAuthor: z1000puddin » Fri Jan 10, 2014 12:42 pm
zed1015 wrote:1. Bikes pre 1986 need only one brake light switch and it must be operated from the front brake ( Post 86 need both front and rear brake switches if originally fitted)
My black zed has never had a front brake light switch - Only the rear and has been through various MOT testing stations since 1996 and passed ??
Stu
Zed til Dead
jimmock
#6 PostAuthor: jimmock » Fri Jan 10, 2014 1:28 pm
Most of my older stuff only had a stop switch on the REAR ??
Jimmock. :wnkr
I hate people I don't like !
#7 PostAuthor: Pigford » Fri Jan 10, 2014 1:41 pm
Think Rob meant REAR :wink:
Jay1969
#8 PostAuthor: Jay1969 » Fri Jan 10, 2014 1:55 pm
Pigford wrote:Think Rob meant REAR :wink:
Pigford, that's my alternative to "tail light".
I always always say "rear light" instead of "tail light". :wink:
jimmock
#9 PostAuthor: jimmock » Fri Jan 10, 2014 2:12 pm
Is that the RED one at the back??
Jimmock. :wnkr
#10 PostAuthor: zed1015 » Fri Jan 10, 2014 2:16 pm
Stu
OOPS! My balls up.
Should have said either front or back and have amended the post accordingly.
Off the front is preferable though as it's the one that's used the most.
Jay1969
#11 PostAuthor: Jay1969 » Fri Jan 10, 2014 2:27 pm
Jimmock, I always always prefer red lenses on vehicle rear
lights to those modern clear translucent plastic one's.
jimmock
#12 PostAuthor: jimmock » Fri Jan 10, 2014 2:48 pm
I agree.
Red is best!!
Jimmock. :wnkr
Royalratch
#13 PostAuthor: Royalratch » Fri Jan 10, 2014 3:07 pm
This be it.
#14 PostAuthor: ADRIAN H » Fri Jan 10, 2014 8:39 pm
That is fat tyre you have there. I approve, like the tail light too. Ace. . :D
