Couple of quick ST queries please....
Does the exhaust from a mark II/H fit on an ST? If not can it be made to fit? What are the aftermarket/pattern exhaust choices for the ST? I saw a Marving option on ebay but you need the original downpipes. Anything else?
Many thanks
ST question
malmojoe
The frame's are different, I am sure the mounting point(s) for the silencers are different but a bracket could be adapted. I had an Alfa and a Vance & Hines on mine, Alfa was specific for the ST, V&h had to be adapted.
The ST can be converted to chain, I have the info required somewhere. I have seen a Z1R tank fitted but not sure if it had been modified. ST frame is very wide at swingarm if you wanted to update the running gear and do the chain conversion.
jonathan wrote:Thanks Redbeard. Personally I'm not worried about the drive but I think the non-ST exhaust looks better. Were either of those exhausts the same look as the OEM?
Both were 4-1, the ST had 4-2 pipes as standard. The Harris also fits fine, like others say, most big zed pipes fit with some fettling of the rear bracket. There is a replica ST exhaust or at least one that looks almost identical but not sure of the make.
