Clutch and throttle cable lengths z1000
Redbeard
#1 PostAuthor: Redbeard » Sun Dec 15, 2013 10:11 am
I'm going to do away with the high bars on the Ltd so will need shorter clutch and throttle cables. I have some Superbike bars to use, which are somewhere between drag bars and standard J type bars in height and slightly wider tan both. If I can use standard length cables off another zed that would be easier. Could someone confirm the lengths for me please? I just need the clutch and throttle 'pull' cables. Thanks.
#2 PostAuthor: Al » Sun Dec 15, 2013 10:49 am
Standard J clutch cable outer length is 47 inches.
Standard J throttle cable outer length is 36 inches.
Clutch cable measured from ferrule to ferrule ring (lower end).
Throttle cable measured from ferrule at the carbs to the; knurled 'sleeve adjuster locking nut' that butts to the outside of the RHS switchgear. It does not include the curved plastic part which sits inside the switchgear plastic housing.
#3 PostAuthor: z1bman » Sun Dec 15, 2013 11:11 am
z1r or z1000m2 cables will probably do the job
Redbeard
#4 PostAuthor: Redbeard » Sun Dec 15, 2013 2:49 pm
Thanks gents, Al great info as always. I put the bars on this afternoon, I'm not sure the throttle assembly is standard, but I've nowt to compare it to. It's just a pull cable assembly. Due to the width of the bars, the existing cables aren't excessively long but I will replace them anyway as a precaution. I will put some pics up.
