Frame - rear section shortened, seat and suspension mounts repositioned to accommodate wider swinging arm and shorter seat. Tail piece mounts repositioned. Powder coated in black. Seat pan shortened and reshaped to fit frame with new mounting points all aligned.
Swinger - ZRX 1200 with modified shock mounts aligned with frame, powdercoated in dark grey to make it stand out from the rest of the chassis.
Bodywork - custom painted in Kawasaki wildfire orange pearl, Z1b pattern with black/red custom striping (fishnet black airbrushed with fade in over metallic red). Very nice and expensive! Sidepanels have No.7 logo as the whole project was themed as No.7 as a bit of a piss-take! Tank fitted with flush fit filler cap, hole reworked and welded to suit, pressure tested.
Front end - USD 2003 Z1000 complete. Forks extended and anodised black.
Yokes - custom made for forks, stepped alloy, new stem, anodised black.
Wheels, Z1000, 6" rear newly powder coated in satin black.
That's it for now, more pics the weekend I hope or over christmas if not
