On the way back my indicators stopped working, I have traced it back to the flasher unit, has anyone got a spare one or point me in the right and most cost effective direction where to buy a new one?
Got a 83 Z1000R
Thanks in advance guys
Z1parR wrote:Ian it would appear that you have bought the wrong machine for your country .
Z1000R's and Z1100R's were notorious for their problem electrics in warmer climates .
I suspect this is just the beginning of your electrical woes .
You did import it if i remember rightly from a cooler country where it will have worked fine
tlc wrote:Any decent auto parts store should be able to get one.
Durite make what you need.
http://www.durite.co.uk/pdf/2012/6/06.4 ... _units.pdf
tlc wrote:You should be able to get one down there no problem.
if not let me know and I can send one down to you.
nzphil wrote:Recently bought one for my Z1 from Supercheap Auto, there are several in Brisbane, any 2 pin 12v unit will work.
Users browsing this forum: No registered users and 4 guests
