530 front sprocket problems
Big Fluff
#1 PostAuthor: Big Fluff » Sun Oct 14, 2007 12:48 pm
Trying to sort the 530 chain & sprockets out on the Saxon Turbo but it's doing me head in. :star
At the moment it has a 19 tooth front sprocket on, but;
1. I've run out of adjustment (Rickman frame)
2. It seems to be dished outboard too much (7mm offset)
3. I reckon it'll be way overgeared, especially with a 38 tooth rear sprocket
The chain is quite a chunky bugger being the 'X'-ring type aswell.
So all you guys, is there an 18 tooth, 530 sprocket available, off the shelf, with a smaller offset. I reckon if it had no offset, the chain might touch the inner chain cover, if not it'll be damn close.
Thanks as always, Will
Pasc
#2 PostAuthor: Pasc » Sun Oct 14, 2007 2:59 pm
Fluff, I've always found the chap at B&C Express very helpful. He might be worth a call to discuss alternative sprockets. There is a gearing calculator on the web somewhere but I can't find it right now. Check this one out. You might be able to edit one of the provided models to suit your setup.
http://750turbo.com/forum/viewtopic.php?t=4484&highlight=sprocket+calculator
#3 PostAuthor: Rich » Sun Oct 14, 2007 5:48 pm
JT list all the sizes for different bikes
http://www.jtsprockets.com/
Put a spacer behind the sprocket as long as you are on the splines and have a full nut on then you should be Ok
Big Fluff
#4 PostAuthor: Big Fluff » Sun Oct 14, 2007 6:25 pm
Rich wrote:JT list all the sizes for different bikes
Rich.
Tried JT but they only do straight fitment. As you probably know there's no room for and kind of spacer on the Z motor and the 7mm offest I have at present is too much.!
I had my rear sprocket made at B&C, will have to see what they can do but they only do made to measure for the rears I think ? Will see tomorrow.
Thanks. Will.
Padders
#5 PostAuthor: Padders » Mon Oct 15, 2007 1:01 pm
Please see my reply in your other thread. sorry only just seen this one!!
padders :oops:
