v&h baffle
v&h baffle
Has anyone got a baffle for a v&h drag pipe knocking around? could do with a badge too. or could i make one (baffle), they are more expensive new than the exhaust new? thanks.
- london calling
The sidewinder drag pipe mega doesn't have a baffle.
http://www.ebay.co.uk/itm/131022738785? ... 1555.l2649
Jack
Hello Adam,
I used the baffle from my standard V & H street pipe on my Pro-pipe, and is ideal for road use. So if you can find one of those that will fit fine. If you can`t get one, let me know, and I could get you dimensions if you want to try and get a copy made. Or if you are in the area, you are welcome to borrow it if you like.
AndyZ1R wrote:Hello Adam,
Hi Andy, thanks for the help. I may have sourced one for now. I hope to get a photo of it later which may help to identify it. Cheers again.
Redbeard wrote:AndyZ1R wrote:Hello Adam,
No problem Adam, let me know if that one doesn`t work out. Put the pic on here if you can and I`ll compare it if you like?
