v&h baffle
Redbeard
v&h baffle
#1 PostAuthor: Redbeard » Fri Oct 25, 2013 10:23 pm
Has anyone got a baffle for a v&h drag pipe knocking around? could do with a badge too. or could i make one (baffle), they are more expensive new than the exhaust new? thanks.
london calling
#2 PostAuthor: london calling » Sat Oct 26, 2013 2:33 pm
The sidewinder drag pipe mega doesn't have a baffle.
http://www.ebay.co.uk/itm/131022738785? ... 1555.l2649
Jack
Redbeard
#3 PostAuthor: Redbeard » Sat Oct 26, 2013 3:27 pm
I think that's different to mine, I will have a look and post a pic. I had one on my st with a baffle, and the seller sold it saying the baffle was missing. it'll be a bit loud then. the marshall I have has to be removed every time the filter is changed.
marlin
#4 PostAuthor: marlin » Sat Oct 26, 2013 9:15 pm
sidewinder with a baffle ? cheers martin
Redbeard
#5 PostAuthor: Redbeard » Sat Oct 26, 2013 9:36 pm
maybe i got the identity wrong. will check tomorrow and get a pic up on here.
AndyZ1R
#6 PostAuthor: AndyZ1R » Sat Oct 26, 2013 10:49 pm
Hello Adam,
I used the baffle from my standard V & H street pipe on my Pro-pipe, and is ideal for road use. So if you can find one of those that will fit fine. If you can`t get one, let me know, and I could get you dimensions if you want to try and get a copy made. Or if you are in the area, you are welcome to borrow it if you like.
Redbeard
#7 PostAuthor: Redbeard » Sun Oct 27, 2013 9:37 am
AndyZ1R wrote:Hello Adam,
Hi Andy, thanks for the help. I may have sourced one for now. I hope to get a photo of it later which may help to identify it. Cheers again.
AndyZ1R
#8 PostAuthor: AndyZ1R » Sun Oct 27, 2013 10:27 am
No problem Adam, let me know if that one doesn`t work out. Put the pic on here if you can and I`ll compare it if you like?
Redbeard
#9 PostAuthor: Redbeard » Sun Oct 27, 2013 5:54 pm
will do andy, hopefully I can get a pic taken tomorrow when I get in if my garage is still standing..
Redbeard
#10 PostAuthor: Redbeard » Mon Oct 28, 2013 5:14 pm
Took some photos of the exhaust. Couldn't see any identity markings. The hole in the end suggests it had a baffle at some point, possibly a non-factory one.
AndyZ1R
#11 PostAuthor: AndyZ1R » Tue Oct 29, 2013 11:36 pm
Hello Adam,
That looks the same as my pipe, the V & H pro pipe (sidewinder) came with that hole in the end to enable you to fit a standard baffle in it, which is what I did. So if you can get a standard street pipe baffle then that will be fine.
Regards,
Andy
Redbeard
#12 PostAuthor: Redbeard » Wed Oct 30, 2013 5:50 pm
nice one andy, i shall keep em peeled for a baffle. cheers again!
Users browsing this forum: No registered users and 4 guests
