22mm front wheel spindle.
#1 PostAuthor: Al » Sun Oct 20, 2013 6:11 pm
Does such a thing exist.
Need one for the front end of the J to get shot of those nasty sleeve nuts on a 15mm pipe-cleaner they call a spindle.
Needs to have 225 mm beneath the head plus enough thread to get the nut on.
240mm ish overall i would guess.
Anything about?
#2 PostAuthor: z1bman » Sun Oct 20, 2013 6:29 pm
are you using the standard wheel & forks ?
#3 PostAuthor: Al » Sun Oct 20, 2013 6:49 pm
Standard Z1000J forks and a non standard front wheel.
The spacers that fit inboard of the legs will be shouldered as they are now to prevent the legs moving together.
The main aim is to get a larger diameter spindle and since the bearings as standard have a 25mm internal diameter there is room enough for tinker time.
Bearing outside diameter is 52 mm so no option but to sleeve as bearings dont come in 52 outer and 15 inner so some sort of sleeving will have to take place somewhere.
These wheels come with bearing reducers as standard but they are missing so more tinker time for me as a necessity.
#4 PostAuthor: Ginger Bear » Wed Oct 23, 2013 5:37 pm
Any good Al?
22mm dia, but not sure if the other dims work for you. From a late model GSXR600 I believe.
# 104
#5 PostAuthor: Al » Wed Oct 23, 2013 6:21 pm
Thank you Steve, e-mail sent with a list of questions.
Just what you need i bet.
Z1parR
#6 PostAuthor: Z1parR » Wed Oct 23, 2013 6:32 pm
I've a 20mm spindle thats 300mm long Al .
Apart from being the wrong diameter and length it'd be perfect :up
0172 . Geoff Parr
#7 PostAuthor: Al » Wed Oct 23, 2013 6:40 pm
Apart from being the wrong diameter and length it'd be perfect Thumbsup
Geoff could it be built up with araldite and sanded down?
Z1parR
#8 PostAuthor: Z1parR » Wed Oct 23, 2013 7:00 pm
Not sure i'd trust araldite Al , you'll not go far wrong using silver solder though :D
0172 . Geoff Parr
#9 PostAuthor: Al » Wed Oct 23, 2013 7:38 pm
Misled you there sorry.
Araldite is our family's name for my mums apple crumble.
Have used it to repair the drive here and its still going strong four years later.
#10 PostAuthor: Ginger Bear » Thu Oct 24, 2013 6:37 am
zorded wrote:Thank you Steve, e-mail sent with a list of questions.
No email here Al...... Feel free to try it again.
# 104
garyd
#11 PostAuthor: garyd » Thu Oct 24, 2013 4:02 pm
Al...in my list of data I have....
22mm
FJR1300
Sorry no length though
#12 PostAuthor: Al » Thu Oct 24, 2013 9:34 pm
Thank you all.
May go a jumbling on Saturday at Kempton Park but will keep in mind whats been said.
