1170 on J head, GPz Barrells
Taffus
#1 PostAuthor: Taffus » Thu Oct 17, 2013 11:08 am
I seem to remember being told that if you fit a 1170 kit to a J series engine the pistons can hit the valves. Does anyone know about this or can I continue on fitting the J head to a GPz 1100 b1 including cams (b1)
(\__/)
(")_(")Image
big green bus
#2 PostAuthor: big green bus » Thu Oct 17, 2013 2:08 pm
I have done it loads no problems
Taffus
#3 PostAuthor: Taffus » Thu Oct 17, 2013 3:06 pm
Cool! Thanks onward we go!
(\__/)
(")_(")Image
Robw
#4 PostAuthor: Robw » Thu Oct 17, 2013 7:51 pm
Only a problem if you fit oversize valves. As I found out :oops:
Rob
#5 PostAuthor: Ginger Bear » Thu Oct 17, 2013 8:49 pm
Mark.
I think the UniTrak head had different valve angles, so need's different Wiseco's.
Maybe that's what was in the 'back of your mind'?
# 104
Taffus
#6 PostAuthor: Taffus » Thu Oct 17, 2013 10:36 pm
Hi Steve,yes you're right!It was Al who explained it to me and has explained it again tonight :roll:
At least I remembered there may be a problem and I didn't barrel along as I usually do :D
(\__/)
(")_(")Image
