I.m confused, new aftermarket rings for Z1000 70mm, both are marked top, one is shiney no inside or outside bevel, other is black/blue with inside bevel and marked top on bevel side.
So does ring with inside bevel (facing up as marked top) go on top groove or second.
COMPRESSION RINGS- INSIDE BEVEL UP
Yes, shiny ring on top.
The ring with the bevel/step on the inside goes bevel/step side facing upwards.
A note.. Some early zeds (72/73) had the bevel facing downwards (gen kawa rings only) which threw a lot of zed enthusiasts into total confusion. Nowadays even rings for those early zeds that are not genuine nos should also be fitted with the bevel facing upwards.
Thankz Rob and Will.
Above is answer to the bit that threw me, always thought inside bevel faced down on second ring.
Correct me if wrong, l,ve seen rings with inside bevel face up on top groove?
