GSXR 750 flatslides
pluto
GSXR 750 flatslides
#1 PostAuthor: pluto » Mon Oct 07, 2013 8:09 pm
Hi All,
I have bought a good set of these to put on my Gpz1100B2, I have found an old post by Nanno with his jetting recommendations for when they are fitted to a 1000J. My bike is bored to 1170 so my question is, are the settings likely to be similar? I need to get it running half decently to then get it set up on a dyno later on.
Other questions.
Which is the best push pull throttle? APE seems cheapest.
I have seen a lot of Gsxr's with 1 K and N filter for each pair of carbs. These are quite reasonably priced, any pros or cons?
Any other tips or advice greatly appreciated
Many Thanks
Dave
#2 PostAuthor: ADRIAN H » Mon Oct 07, 2013 8:24 pm
I know Debbens sell these.
http://www.debben.co.uk/ppt100.html
big green bus
#3 PostAuthor: big green bus » Mon Oct 07, 2013 10:10 pm
martinz1000r
#4 PostAuthor: martinz1000r » Tue Oct 08, 2013 7:52 am
I had a set fitted to my 1170 Moto Martin. I can take the float bowls off and have a look for you if you like but it might be closer to the weekend before i get a chance.
Also which GSXR carbs? Metal topped ones off the early slabbies or plastic top off the later slingshot? Mine are slingshot. Not sure if it makes a difference on jeting but i think the bore is bigger
pluto
#5 PostAuthor: pluto » Tue Oct 08, 2013 5:40 pm
Hi All,
Thanks for the input, The carbs I have are from a gsxrh slabbie, vm29ss I think, so thanks for the offer Martin but mine are different.
Dave
london calling
#6 PostAuthor: london calling » Fri Oct 11, 2013 9:00 am
Dave,I've bought the K&N Duplex type air filters for my flatslides.
I'm sure I was told the larger surface area/volume gives better running characteristics.
Here is a link to this type of filter,as always mucho cheaperier in the U.S.A.
http://www.knfilters.co.uk/search/produ ... od=RU-2920
Jack
