Hi all,
Apologies but I'm fairly new to bikes and haven't much technical ability so sorry if this sounds like a stupid question.
The kick start on my Z1 has no resistance - it just swings on through.
I have a Sukuki SP370 and it nearly breaks my foot try to kick through.
Any idea what is wrong with the Z1.
Thanks.
No Kick Start
mickey marley
sounds like there is no gear the other end but that's just weird. Yuo'll need to get at the shaft to look by the sounds of it.
the bad news is you can't get the shaft out without splitting the engine.
a winter job - ride it until it gets too cold.
i assume (hope) the electric boot is working fine......
i have some kickstart shafts in my spares boxes.
Streetfighterkz
mickey marley
Also, it would be worth checking if the spring may be
worn out or broken
worn out or broken
Non standard Z900 - purchased from HIGGSPEED - http://www.higgspeed.com/ -
http://www.z1ownersclub.co.uk/forum/vie ... 6a7d5e816c
