No Spark quandary !!!!
Tonto
#1 PostAuthor: Tonto » Sat Aug 31, 2013 1:57 pm
I've posted before, but the feckin gremlin wont go away :evil: :evil: : any advice chaps ??
Ive an A4 which runs fine except for an annoying intermittent misfire on cylinder no 3, which is down to there being no spark. Oddly if I put new plugs in she would fire up - but from eperience in a couple of weeks I will be back to having a Z900 triple !.
Today I changed my coil, with new HT leads and caps: and as usual no 3 refused to fire up - again there was no spark: so I tried a shiny new plug to number 3: no better: so, I fitted yet another NGK plug and got a spark and the bike is now running spot on.
I don't know what to do next, and can't think what can be causing the isolated probs to No 3 electrics. Is it possible I got a duff set of NGKB8ES plugs ? has anybody else had issues ??
Would Iridium plugs make any bleedin difference ??
Cheers Tim
Z900 A4 / KZ1300A1 / H1F 500 Project / CBX Project / RD350 project / GT750A Kettle / BMW R NineT
#2 PostAuthor: z1bman » Sat Aug 31, 2013 2:11 pm
highly unlikely to be the coil as they work in pairs. if you purchased the plugs from e bay + they where cheap they could be copies. try another make like denso + buy them from a retailer not from the internet. is the plug fouled when you remove it ? make sure you have battery voltage at the coils
andyb1962
#3 PostAuthor: andyb1962 » Sat Aug 31, 2013 8:57 pm
have you swapped HT leads round Tim?
it will at least eliminate a dodgy lead
Andy :wink:
andyb1962
#4 PostAuthor: andyb1962 » Sat Aug 31, 2013 8:58 pm
have you HT leads round Tim?
Andy :wink:
Tonto
#5 PostAuthor: Tonto » Sat Aug 31, 2013 10:17 pm
Andy / z1bman
I never thought of swapping the HT leads around !
The coil removal was solely to get shot of the HT lead (which I thought was probably the culprit) and was bonded in and could not easily be removed.
Imagine my pleasure after fitting the new coil, leads and caps to find I still wasn't getting a spark. Anyway I raided a new plug from my Kettle resto, and I have a spark. Took her out this afternoon for a 30 mile blast, and she ran perfectly. Will defo be buying some new quality plugs.
See what happens tomorrow :?? :?? Cheers Tim
Users browsing this forum: Google [Bot] and 14 guests
