wheels and charging
royboy
wheels and charging
#1 PostAuthor: royboy » Sat Aug 17, 2013 12:52 pm
hi all
do you know if the z650 wheels will fit the z900 A4,+ bike was charging
14.6v across battery now only 12 to 13.2v,tried to check the 3 yellow wires from stator but getting 18.2 on all 3 wires am I doing some thing wrong.
when running with lights on they are dim and when revving up the lights get bright.asking because battery goes flat { new battery }would flat battery
cause missing at low rpm.
thanks royboy.
000zeds
#2 PostAuthor: 000zeds » Sat Aug 17, 2013 2:28 pm
Front wheels are the same but not sure about rear :!:
Zeds-R-Us
Jay1969
#3 PostAuthor: Jay1969 » Sat Aug 17, 2013 2:52 pm
Battery problem would be your regulator/rectifier unit.
Charlie
#4 PostAuthor: Charlie » Sat Aug 17, 2013 3:25 pm
The axle is smaller on the rear of a Z650. It's 17mm as opposed to the Z900's 20mm so you would have wheel bearing issues at least.
royboy
wheels
#5 PostAuthor: royboy » Sun Aug 18, 2013 10:03 am
thanks all will try new reg/rec,and not the wheels
#6 PostAuthor: z1bman » Sun Aug 18, 2013 10:35 am
z650 front + rear wheel axle size's are identical to the z 900
Charlie
#7 PostAuthor: Charlie » Sun Aug 18, 2013 12:12 pm
Z650 rear spindles are only 17mm. I have one on my bench. Z900's use 20mm rear spindles...
