over shift bushing
over shift bushing
where exactly does the bush fit on the transmission
Are you fitting an air shifter ? as you only really need it if you are.
It goes on the end of the selector fork shaft behind the inner case that holds all the seals for the output shaft, clutch pushrod and gear selector.
You need to remove the gear lever, outer sprocket cover, front drive sprocket and then the inner cover and then it just slots on the end of the shaft next to the selector mechanism.
