fuel tap
zman
fuel tap
#1 PostAuthor: zman » Tue Jul 30, 2013 1:42 pm
I have a fuel tap with two outlets.One out let flows about twice as fast as the other.I assume that they should flow the same :?:
The one that flows slow is feeding a pair of carbs that are running rich.So was thinking this may be the problem
keep thoses wheels turning
#2 PostAuthor: ZedHead » Tue Jul 30, 2013 2:58 pm
While fuel starvation would probably lead to a lean mixture I doubt that fast flow would make it rich since fuel height is governed by the float valve.
zman
#3 PostAuthor: zman » Tue Jul 30, 2013 3:26 pm
My thought was that when running this could creat a low fuel leal.so could this then creat bad atomisation which may then creat a rich mixture
Re: ---
#4 PostAuthor: Pigford » Tue Jul 30, 2013 3:33 pm
zman wrote:My thought was that when running this could creat a low fuel leal.so could this then creat bad atomisation which may then creat a rich mixture
Hmmm - if float level is LOW - then it should be running lean :|
Re: ---
#5 PostAuthor: ZedHead » Tue Jul 30, 2013 3:35 pm
Low fuel level would give you a weak mixture.
Users browsing this forum: Google [Bot] and 19 guests
