can you register a special? (bitza)
malmojoe
#1 PostAuthor: malmojoe » Sun Jul 14, 2013 2:57 pm
I've haven't got started yet but I've been collecting stuff for a couple of years to put together a nice special.
Now, I don't know if it's worth going ahead or whether I should put it all on ebay. Will I be able to get it registered? Seems it's getting near impossible to get a bike on the road. And if I can, can I get an age related plate?
Does anyone have any facts they would like to share?
ears
G
#2 PostAuthor: chrisu » Sun Jul 14, 2013 4:05 pm
easiest way is to have a frame with a V5 - if you have that its pretty easy - otherwise I suspect a Q plate will beckon.....
weaver
#3 PostAuthor: weaver » Mon Jul 15, 2013 7:23 am
as above-if you have frame and v5 use that as the bikes identity no need to register
lude
#4 PostAuthor: lude » Mon Jul 15, 2013 9:47 am
As its made of bits, and if you've got no v5 then you could be going down the Motorcycle Single Vehicle Approval route. You may be able to get a dating cert from kawasaki and try registering it that way.
http://www.dft.gov.uk/vosa/repository/MSVA%20Guide.pdf
Easiest way is to get another frame with v5, or did you know the old reg number ?
Taffus
#5 PostAuthor: Taffus » Mon Jul 15, 2013 9:52 am
I'm guessing that it's a "Smörgåsbord" mostly non UK parts?
jeg elske dig flappe kusse!
(\__/)
(")_(")Image
malmojoe
#6 PostAuthor: malmojoe » Mon Jul 15, 2013 10:33 am
Very good Mark :). No it's a 74 frame which I was told had been registered but actually has no record so I guess it's from the US. The rest is aprilla, ZrX and big swing arm stuff picked up in the UK.
Got a matching engine for it so would be a pain to find another frame.
So if I went ahead, it would be possible but I would probably have to have a Q plate?
Do you need to supply VAT receipts for all the parts?
wilsonsjw11
#7 PostAuthor: wilsonsjw11 » Mon Jul 15, 2013 11:07 am
Dating letter from Kawasaki is only obtainable if the number and frame match their records in Japan and are shown to have been assembled on the same day.
Regards
Steve
#8 PostAuthor: chrisu » Mon Jul 15, 2013 11:13 am
as its a special i'd be tempted to buy a frame with a V5.......
