I've haven't got started yet but I've been collecting stuff for a couple of years to put together a nice special.
Now, I don't know if it's worth going ahead or whether I should put it all on ebay. Will I be able to get it registered? Seems it's getting near impossible to get a bike on the road. And if I can, can I get an age related plate?
Does anyone have any facts they would like to share?
ears
G
can you register a special? (bitza)
As its made of bits, and if you've got no v5 then you could be going down the Motorcycle Single Vehicle Approval route. You may be able to get a dating cert from kawasaki and try registering it that way.
http://www.dft.gov.uk/vosa/repository/MSVA%20Guide.pdf
Easiest way is to get another frame with v5, or did you know the old reg number ?
Very good Mark
. No it's a 74 frame which I was told had been registered but actually has no record so I guess it's from the US. The rest is aprilla, ZrX and big swing arm stuff picked up in the UK.
Got a matching engine for it so would be a pain to find another frame.
So if I went ahead, it would be possible but I would probably have to have a Q plate?
Do you need to supply VAT receipts for all the parts?
