cometic head gasket
- PETER KZ1A
cometic head gasket
Does the C8018 cometic head gasket suit a standard bore 900 Thanks
No
http://www.ebay.com.au/itm/WISECO-KZ900 ... _607wt_914
Yes
http://www.zpower.com.au/catalog/produc ... e7f62d336d
Maybe. I.m confused as I.m chasing one myself.
Yes
I can't understand "Cosmetic" covering 900 thru to 1075 with the one gasket.
There is a difference in the size of the bore hole in the 900 and the 1000 gaskets.
I think there is a chance of the 900 gasket being exposed to combustion if fitted to the larger bore. Conversely, when the 1000 gasket is fitted to the 900, you must be sacrificing sealing area!.
Re: cometic head gasket
PETER KZ1A wrote:Does the C8018 cometic head gasket suit a standard bore 900 Thanks
No.
http://www.powersportjunkie.com/COMETIC ... -c8018.htm
- PETER KZ1A
