GPZ1100, Z1100R Exhaust Collets Wanted
I had a set, but can't find them and it's holding up the Harris rebuild. If anyone has a set to sell I would really appreciate it.
Rod
Rod
- big green bus
- big green bus
- big green bus
- big green bus
He said £40 delivered for one set, but £30 a set if he gets six orders , he also said to measure the inside diameter of the clamp to be sure, he thinks the size is for the larger ones not the GPz/Z1000j type, Zorded could you confirm the length of your gpz ones please as he will not take them back if the measurements are wrong.
I've got two piece ones at 38mm by 28mm deep for the J1 with J head same as Unitrak head which it has now. These are fitted to a set of Laser headers.
The Laser headers are a very tight fit in the exhaust port counter-bore!!
These are the ones with the one piece cast alloy clamp.
I also have some one piece ones from a Marshall which is a J fitment Stamped Z1000 J which are 37mm minor diameter and 30mm deep. These have a major diameter of 48mm. The Marshall headers are noticeably smaller in diameter than the Laser ones fitted at this time.
The diameter of the Marshall headers is 33mm.
These have a steel plate for a clamp rather than the above
Hope this helps.
Hope this helps.
- big green bus
z1bman wrote:standard ones part no 92027-1300 cradley have them in stock
Kawasaki Part Number Displayed: 920271300
Kawasaki Part Description: COLLAR,EXHAUST PIPE
Kawasaki Part UK(£) Price: £2.75
Not too expensive for the standard ones, it is up to you if you go for them or the stainless steel.
(is anybody who has had the S/S ones had any problems with them ?)
big green bus wrote:z1bman wrote:standard ones part no 92027-1300 cradley have them in stock
I might as well go for the Kawasaki ones, never bothered to phone them because I thought they would be extortionate, but 2.75 is not too bad if that's for 1 set. I'll give em a call and check.
Rod
