Z800 Cafe Chopper Fighter thing...
j.wilson
#136 PostAuthor: j.wilson » Sun May 26, 2013 10:09 am
Yep, I'm tempted into a CNC project for the same reason- I even downloaded and plan for a home build project.
I dreamt about making a wall mounted machine to save space.
But in the end I think it would be better to start with a manual machine that is designed for the loads. For example, is made of cast iron and has large contact areas on its bearings. My wall mounted idea started to look a bit dumb.
Such a project would need to have ball screw conversions so there is no backlash and then the servos fitted.
After that its a purely tech project and there are lots of servo/driver/interface kits to get you going.
Would make a great project. I don't have enough space.
You could buy something off the shelf like this?
http://shopmasterusa.com/general-features/
$5700 plus shipping and VAT.
Is that too much to dream about?
My head goes round in circles a bit about this.
z650/1400 bonneville hybrid.
#137 PostAuthor: Rich » Sun May 26, 2013 5:36 pm
I'm thinking of going CNC - so I can sit and watch it turn out beauty in alloy, unfortunately those with the capacity to do yokes etc seem to take up space disproportionate to their capacity so it looks like manual for me!
Royalratch
#138 PostAuthor: Royalratch » Sun Jun 02, 2013 11:37 am
So have front spacers on the way but there's more mount issues on the rear top and lower mounts too. :roll:
Theres also a pacer needed there. As you can see the gap here in green - about 20mm.
Another major issue that concerns me is the right side upper mount. The triangle that also has the bracket for the rear brake switch fouls the right side engine cover as there appears to be some big useless tab sticking out of it?
As you can see, on the 650 its not present.
But there is this on the right side cover which I presume is the clutch cable actuator? I don't need that triangular bracket as I'm running a rearset mounted switch / reservoir but is that bracket needed to actuate this? Do I get a new cover or machine that tab off?
The rear lower mount rod is also not long enough by 10mm.
I didn't think there would be this much difference.
Crofty
#139 PostAuthor: Crofty » Sun Jun 02, 2013 12:28 pm
Ratch, The GPZ cases are slimmer at the rear. No problem, just make a couple of spacers.
The 650 cases are same width top and bottom at the rear, IIRC its 175mm.
The GPZ A1 cases I have are 158mm bottom and 165mm top.
You need the lug on the clutch cover there is a threaded hole in the back for a bracket that holds the end of the clutch cable.
You will need to either remove the brake switch bracket from the mount or get a new triangular engine mount plate made.
Not sure why the lower rod is not long enough though if the cases are narrower, a 650 one should be long enough, Are you using 750 ones?
Crofty
Royalratch
#140 PostAuthor: Royalratch » Sun Jun 02, 2013 12:36 pm
Yeh I think they're 750 ones.
So that lug is needed.
Crofty
#141 PostAuthor: Crofty » Sun Jun 02, 2013 12:51 pm
try 650 bolts and DO NOT remove the lug it is needed for the clutch release, I have a spare bracket if you do not have it.
Easiest way is to fab up a new engine mount plate and spacers at the rear.
Royalratch
#142 PostAuthor: Royalratch » Sun Jun 02, 2013 2:01 pm
That triangle has deep threaded sections on it. Will remove it - I like making some sparks fly.
That link piece would be much appreciated dude.
Crofty
#143 PostAuthor: Crofty » Sun Jun 02, 2013 4:26 pm
Ratch, pm me your address and I will put the bracket and bolt in the post.
Keep the threaded bits on the triangle bracket, just grind off the brake switch 'L' shaped bracket which sits outermost.
Jim
j.wilson
#144 PostAuthor: j.wilson » Sun Jun 02, 2013 11:03 pm
Its worth noting- if you have a need for some fancy engine bolts- go surfing the parts fische for other bikes-- like at cmsnl.com
Often they will list the dimensions for the long engine bolts on the part description- its easy to order one for another bike once you know the dims you need.
Crofty
#145 PostAuthor: Crofty » Mon Jun 03, 2013 9:53 am
Ratch, Bracket in post, you should get it tomorrow morning, Crofty
Royalratch
#146 PostAuthor: Royalratch » Mon Jun 03, 2013 3:52 pm
All sorted. Cheers dudes.
Next question!
I'm thinking the Tockico radial calipers that came with the forks are not badical enough. I'm into a refurbed set of R1 calipers 05 era or a new set of Brembo M4s.
Assuming I order the Brembos to fit an 05 ZX6R they should bolt right on.
Do the R1 calipers fit? They'll both be 108mm bolt spacing but the offset to the disc is what concerns me.
#147 PostAuthor: zed1015 » Mon Jun 03, 2013 4:02 pm
Fitted R1 monoblocks to my 10R forks on the Zed Road Racer.
They needed reducing in height by 5mm.
Offset was not an issue.
See my project for details.
Royalratch
#148 PostAuthor: Royalratch » Mon Jun 03, 2013 10:34 pm
Cheers Rob.
Cos the R1 uses a 320mm disc. So I could save the machining hassle with a bigger disc perhaps.
#149 PostAuthor: zed1015 » Tue Jun 04, 2013 8:14 am
Bigger discs would do the trick if they're available but will be £££££ more than machining the calipers for the same result.
750steve
#150 PostAuthor: 750steve » Wed Jun 05, 2013 9:12 am
Calipers from most of the modern jap bikes will interchange as the offset is in the disc, not the caliper. I've 2011 Fireblade Monoblocks on my ZX10 forks with some spacers & im using 1999ish ZX6 300mm front discs.
What diameter of discs are you using again?
