Anyone got a rear disc for Z900A5?
It's 275 mm dia'...mines been drilled and has cracks across in 3 places!
Thanks,Keith.
It's for the 5.00-16" wheel, custom type.
Rear disc/5-16 wheel 900A5
rear disc/5-16 wheel 900A5
Hi...I have a disc on my A2 1000 that I might be selling as gonna uprate the running gear. ..dont know if it's any good to you or you have a disc now?. ..i would want £50...
Hi Keith is this any good?
http://www.ebay.co.uk/itm/Kawasaki-Z900 ... 2ec882885a
I'm a bit confused over the 6 bolt fitment. All the 900 and z1000 b models I've seen only have the 4 bolt mount.
Gus
Gus
"Set the GRINDER on it"
Gus wrote:Hi Keith is this any good?
Gus
Hi Gus,good find.
The bike is a bit of a mix?
KZ900 A5.has 5-16" rear wheel so guess it started life as Custom CSR?
It now has Zephyr 1100 engine !
Seems the back wheel has been machined to get chain to line up.
Getting Z650 disc drilled(,this one has 6 bolts?),also getting a sprocket re drilled to fit.
Thanks for your help
Users browsing this forum: No registered users and 5 guests
