Exhaust smoke after throttle shutdown
z1000puddin
#1 PostAuthor: z1000puddin » Sun May 26, 2013 3:18 pm
Guys,
I had a hundred or so miles on my 1075 zed. yesterday.
My mate following noticed that there was smoke coming from the exhaust when the throttle was shut-down. Noticeably when it was getting a good thrash.
The bike has new MTC piston & rings
28mm carbs with 112.5 mains & 17.5 pilots.
Open ally trumpets
Intend getting it dynod, but I am concerned about the smoke - Should this happen on a rebuilt motor ??
Or should I carry out a compression test. ?
The bike starts & idles well, pulls well although it may need a jet up one or two.
.The bike has done a couple of hundred running in miles.
Stu
Zed til Dead
Charlie
#2 PostAuthor: Charlie » Sun May 26, 2013 3:20 pm
How much smoke and what colour is it ?
#3 PostAuthor: ZedHead » Sun May 26, 2013 3:47 pm
Blue smoke on over run. I would suspect valve oil seals.
#4 PostAuthor: chrisu » Sun May 26, 2013 3:48 pm
jimmock
#5 PostAuthor: jimmock » Sun May 26, 2013 4:49 pm
ZedHead wrote:Blue smoke on over run. I would suspect valve oil seals.
I agree,
on over run it must be stem oil seals and/or guides.
Jimmock. :wnkr
I hate people I don't like !
z1000puddin
#6 PostAuthor: z1000puddin » Sun May 26, 2013 7:15 pm
Thanks guys,
I will get the compression check - just for my own reference.
I whipped out # 2 plug just to check - pic below - does this show a bit lean ?
Zed til Dead
paulmceleney
Chunks
#7 PostAuthor: paulmceleney » Sun May 26, 2013 8:04 pm
no that what everyone want there plugs to look like that is the best
KeithZ1R
#8 PostAuthor: KeithZ1R » Sun May 26, 2013 10:16 pm
Feck me the mythical "straw coloured plug" save it for posterity :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
z1000puddin
#9 PostAuthor: z1000puddin » Mon May 27, 2013 5:37 pm
So you would not advise messing about with the 28mm carbs then.
I thought my current set up of the mains @ 112.5 & pilots @ 17.5 was standard.
And as I have 4-1-2 underseat exhaust, open velocity stacks & andrews 2X Cams - I thought I would need to up jet.
Stu
Zed til Dead
paulmceleney
Chunks
#10 PostAuthor: paulmceleney » Mon May 27, 2013 5:59 pm
Try 130 main jet this will make a difference
it will run better more power I have a under seat exhaust on my z1000 rebored to 1075 gas flowed head z1r cams 33 smoothbore carbs was running 28 mm carbs and 130 jets there is not much difference between z1r carbs and smoothbore carbs in power
z1000puddin
#11 PostAuthor: z1000puddin » Mon May 27, 2013 6:13 pm
Thanks Paul,
The 28mm carbs I have on are from a Z1B.
Do you think I need to go up as far as 130 on the mains ?
It seems a real big jump.
Stu
Zed til Dead
paulmceleney
Chunks
#12 PostAuthor: paulmceleney » Mon May 27, 2013 6:33 pm
yes I ran 150 in my z900 which was a bit to big it still pulled well plus 50 to the gallon went to Germany with the 150 jets in but 130 should be spot on then adjust the air screws even moving them 1mm can make a difference just a little each time
z1000puddin
#13 PostAuthor: z1000puddin » Mon May 27, 2013 9:20 pm
Paul,
What would you suggest for the pilots ? Keep these @ 17.5 ?
What needle position should I set at ?
Thanks in advance
Stu
Zed til Dead
paulmceleney
Chunks
#14 PostAuthor: paulmceleney » Tue May 28, 2013 5:15 pm
I would just change the main jets the pilot jets in my carbs which are 33 smoothbores are 17.5
#15 PostAuthor: ZedHead » Tue May 28, 2013 6:20 pm
Charlie wrote:How much smoke and what colour is it ?
I would go back to this before deciding to play with carbs. Blue = Oil, Grey/White =Rich mixture which, looking at your plugs, I would say is not your problem.
I am not sure if leaking oils seal will show on a compression test? The blue smoke on over run is usually due to the increased vacuum when the throttle is shut off sucking oil passed leaky seals on the inlet side.
