kh250 forks
- ade woollams
kh250 forks
can anyone send me a link where i can view kh250 forks breakdown .all i seem to be able to find under kh is s1 forks and they are not the same.think ive got parts missing in my forks but need to check and have part numbers .thanks
- ade woollams
sorry skibs same again s1 only
Tag Part # Description Price Qty
1 44001-177 FORK-FRONT Not Available
2 44041-037 BOLT-FORK FITTING Not Available
3 92055-1012 in.Oin. RING,FORK TOP $3.86
4 44039-051 HEAD-STEERING STEM Not Available
5 461DA0800 WASHER-SPRING,8MM $1.13
6 44041-044 BOLT-STEERING STEM HD Not Available
7 44041-042 BOLT-STEERING STEM HD Not Available
8 92015-1124 NUT,LOCK,8MM $2.95
9 44045-039 GASKET,FORK COVER Not Available
10 44043-047 WASHER,FORK COVER Not Available
11 44033-067 COTER,L.H FORK Not Available
12 44034-067 COVER,R.H FORK Not Available
13 44032-005 CAP,FORK COVER Not Available
14 44045-029 GASKET FORK COVER Not Available
15 44064-015 GUIDE,FORK COVER Not Available
16 44037-097 STEM,STEERING Not Available
17 461DA1000 WASHER-SPRING,10MM $1.13
18 113B1032 BOLT HEX HEAD 10X32 | Not Available
18 44041-010 BOLT PINCH | Not Available
19 44028-026 SPACER-FORK SP GUIDE Not Available
20 44029-019 GUIDE-FORK SPRING Not Available
21 44026-043 SPRING-FORK Not Available
22 44013-038 TUBE-FORK INNER Not Available
23 44022-034 CYLINDER-FORK Not Available
24 44018-009 PISTON,FORK Not Available
25 44044-019 CIRCLIP,FORK PISTON Not Available
26 44010-035 DUST SHIELD $20.91
27 44044-005 CIRCLIP OIL SEAL FIT Not Available
28 44043-023 WASHER OIL SEAL FIT Not Available
29 44009-026 OIL SEAL $21.71
30 44005-061 TUBE,LH,FORK OUTER Not Available
31 44006-059 TUBE,RH,FORK OUTER Not Available
32 44045-002 GASKET FORK DRAIN PLG $2.54
33 220AA0408 SCREW-PAN-CROS,4X8 $1.13
34 44045-057 GASKET,FORK CYLINDER $2.54
35 44041-040 BOLT-FORK CYLINDER $3.62
36 172BA0830 BOLT-STUD,8X30 $1.38
37 44063-012 HOLDER,FRONT AXLE Not Available
38 92007-031 BOLT,STEERG STEM HEAD $11.70
39 92200-1273 WASHER,16X41X4.5 $6.20
40 46100-003 WASHER,WAVE Not Available
41 92090-007 NUT STEERING STEM LCK $6.38
42 46098-016 CAP, STEERING STEM $3.62
43 92047-006 CONE STRNG STEM BERNG $5.57
44 92037-099 CLAMP-CABLE Not Available
45 411AA0600 WASHER-PLAIN,6.5X13X1 $2.03
46 461DA0600 WASHER-SPRING,6MM $1.13
47 112BA0610 BOLT-UPSET $1.13
- ade woollams
cheers
